Hi everyone, when I grease my front axle spindles I have grease coming out both the top and bottom on one side but only the bottom on the other side.
Is something wrong on the side where it's only coming out on the bottom?
I do have the front end lifted up with a floor jack using my Johnny Bucket hitch as the lift point when greasing.
Thanks!
Probably some old ggrease that hardened up over the years...you can try hitting it with a torch to try to soften it up and make it workable...or you culd remove the spindle sand clean it all out
Or, lower the front to the ground and then hit it again. Should make it easier to appear up top.
