1 - 15 of 15 Posts
And what seems to be that problem GravelyCappy? I am going to move this to the Gravely forum for more attention...hope it works...but do let us know what that problem is
My 566 has not run since last year (no snowblowing this winter in Maryland!). When I went to start it and the battery was dead, I put it on the charger for a couple of days. Still wouldn't turn over. Jump started the Gravely with my other tractor (Kubota B7500 HST) and it started right up. As soon as I disconnected the jumper cable from the Kubota, the Gravely started to stall out. Clamped the jumper cable back on and the Gravely ran fine. Let it idle for a couple of minutes, disconnected the jumper cable, and it conked right out. I'm used to jump starting a car, when you get it running the electrical system runs off the alternator, plus re-charges the battery. Is this a similar situation with my 566? Is the alternator dead, as well as the battery? Any input would be greatly appreciated.
Sounds like the battery is stone dead..if you have a multi meter check it after charging...if you don't have a multi meter.bring it to a place that you would buy a new battery from...have them load test it....I am pretty sure that they will tell you that you need a new one...once a new one is installed I am pretty sure that it will go back to operating properly
Yep. Enough dead cells that it won't hold any sort of charge, not even enough to run the ignition. Scrap it and get a replacement.
You need a new battery... charging that is too much load and keep the engine running too. You could also burn up your charging system trying.
The battery is too far gone to take and hold a charge.....so you need that one way or another...take care of that and I am pretty sure that you problem will be a thing of the past
Discussion Starter #13
What's the best bang for the buck on a new battery. The only numbers I see on it are 6220. It's a 9 x 7 x 8" tall roughly, with the old-style round posts on top.
It really doesn't matter... buy the biggest one that fits the hole and with the posts the right way around. 🍻
1 - 15 of 15 Posts
