1 - 20 of 40 Posts
Hi,
Greetings all, I just picked up my first Gravely. I think it is a pro 12. One plate on it gives me the model number I think of Model 41024 and the serial number is 00604712. Anything anyone could tell me would be great. It has sat for a while so I need to clean the carb I think. I am also looking for a 30" brush deck but I am confused about all the QH system or not and the adapter so I dont know what I really need to make that happen. I have seen a couple of old style brush decks out there but I dont know if they will hook up. Also my engine does not appear to have its ID plate anymore, I think its a K301 Kohler but looking at manuals for that engine my oil dipstick seems to be on the wrong side. Anyway here are a couple of pics, I appreciate all help given :
2443408
2443409
2443410
2443411
Gravely1964
Looks like a pull start pro 10 or 12. Theres a few different ways of a 30. 2 basic styles are quick hitch and non quick hitch.
Heres a new style no slip clutch for a quick hitch
This is one of the 3 different 4 bolt versions of the 30 inch decks. To work on your quick hitch will need something called a retrofit kit. Actually one of those on the sickle bar in above pic
SO is basically what you are saying that I can use any 30 inch deck just that for some I will need a retrofit kit but if I get a new stick QH one that will bolt right on with what I have now ?
Gravely1964
Your machine already has a quick hitch on it. On a pro series you can't remove the quick and bolt on the older stuff. It has a pto brake on it too
So i have to look for one that looks like the one in the first pic that you posted. that is all that will work with mine correct ? I just want to make sure I get the right thing and not one that I end up no being able to actually use.
Thanks much
Gravely1964
Yeah pretty much. The other ones will work with the kit. But the extra fuss with it. All depends on what you can find.
Heres a better pic
So can you confirm that I have a K301 engine, am I on the right track with that ? Also that pic you just posted is that a deck with the retrofit kit ? Or a QH deck ?
Gravely1964
I can't. Its either a 10 hp or a 12hp kohler Magnum series . The shroud has been changed or primed atleast. And thats where the engine numbers would have been. From the looks of the pics the motor and hood has been switched. Different shade of faded red. Last pic is a quick hitch deck on my 5240 I posted
I don't think that's a K301. It's got the oil fill on the end of the oil pan.
Discussion Starter #10
Yeah thats what I thought. Also on almost all K301's that i have seen the dipstick is on the same side as the air filter and this one is not. I am not sure if thats because its a pull start and not electric ? I think most pics I have seen are for electric start ones
Discussion Starter #11
Looking at it again I think the oil fill plug is on the same side as the air filter, I circled it in yellow :
2443426
Also I did get some pics of the 30" brush hog that I could get, is this a Quick Hitch that I can use easily ?
2443427
2443428
Gravely1964
View attachment 2443427 View attachment 2443428
Yes thats a quick hitch deck. Make sure you get the splined coupler that goes from brush hog to quick hitch. As its a pricey item new im told.
You'll have to wait for some of the guys with pros to see about the dip stick locations. My newest is my 5240
Discussion Starter #13 (Edited)
So this deck is missing a key peice then ? I have no idea what a splined coupler is. Sorry I am really new to all this. It did come with this part just loose no idea what it is , I assume this is not the spline thing:
2443437
2443438
Gravely1964
Thats a spare half of the drive shaft for the deck on it now. Its a female splined piece may 3 or 4 inches long hooks from quick hitch to deck spline. With out its more less a paper weight yes. I don't have a pic handy of one
Discussion Starter #18
So i have a pro 12 with the 40 inch mower deck on the front and also bought the 30 inch brush hog as well. I was told all I needed to connect was the splined connector which I bought however I think I have an issue. Whe I took off the QH the dog and trunnion full out. I think I got them back in right :
2445351
However as you can see there is a splined hole where this from the QH goes in :
2445352
I think I need to get that middle splined rod out of the QH so that I can use it to connect from dog to this hole in the 30 inch :
2445353
How do I do that ? Am I doing the right thing ?
Thanks very much
Discussion Starter #19
I did get the QH off and I have the splined connector but now if have this :
2445355
I think I need to get that centre splined shaft out because it will connect the QH 30 inch head to the mower is that right ? Because if not I just have 2 female end
Gravely1964
No you leave the quick hitch on the machine! Brush hog bolts to the front of it! The splined bits line up to the quick hitch shaft
1 - 20 of 40 Posts
