Good afternoon folks....
So I have been having some issues with my Pro-8 running smoothly, and then about 6-8 weeks ago, the machine finally croaks while working it. Suspecting the fuel pump, and then removing the line and visually confirming that no gas is spurting upward, I order a new one, and replace the old one. Bingo--it's up and running again! But not so fast :tango_face_sad: - a couple of days later, I go to start it again, and the same thing happens - machine "wants to start and run," and will run on starting fluid, but not on its own. So today I finally pull the carb (thinking that's the problem), and although the bowl has some residue in it, it looks good. Just for grins, I crank the engine again, and nothing is coming out of the (new) fuel pump deliver side - again :tango_face_sad:. Gas is flowing from the fuel line to the intake side of the pump - and I was able to siphon gas out of the delivery side of the pump as well. But the darn pump will not push the gas through on its own. Any thoughts as to whether I have another faulty pump (it is a aftermarket purchase), or whether I have an insufficient amount of gas flowing for the pump to prime and do its thing - or whether I have something totally different going on?
Thanks for the help!
