So i started into searching for piston rings for the gravely l's as i may need to replace mine. i know richards and gtgravely has them but i wanted to see what my options were. so far here's what i found while searching through cross reference pages from manufacturers (please note all the information below has not been tested)
The direct replacement from hastings is part number 2c7336
Mahles direct replacement is s40061
Grants direct replacement is p0357
the following are the crossed referenced part numbers
Hastings 2c7785
Sealed Power 5648kx
Mahle 540091
Mahle 541372
one of the websites i was on noted that the onan j30 and lk use the same ring sets, the site also mentioned kohler shared the same but did not list the models
i wasnt sure if this should be added on the cross referrence list as i cant confirm all of them work. i just wanted to share my research in the case it helps someone
Hastings 2c7785
Sealed Power 5648kx
Mahle 540091
Mahle 541372
