Maybe in some of the late model ZTR's they made.
GRAVELY's smaller 1200 Series did use "both GEAR drive and HYDROSTATIC drive" & the 5 models were "essentially the same machine" defined by their motors & trannys."Did Gravely use a hydrostatic trans?"
No. Looking at my 21-year old Gravely catalog that came with my 1988 Professional 12-G 4-wheel tractor. They appear to have built essentially the same machine with both GEAR drive and HYDROSTATIC drive. They ended their gear-drive model names with letter "G," whereas they ended their hydrostatic-drive model names with letter "H."
Two more neat var-speed boxes is..."Did Gravely use a hydrostatic trans?"
If you examine gear sets fitted into Gravely gear boxes, you might think that you were looking at automotive transmission power-range gears made to transfer more than 100 horsepower. They are EXTREMELY robust compared to equipment that sold for much lower original prices. I am not willing to disassemble the manual transmissions in my Gravely 9000, Gravely Professional 12-G, Kubota B5100D 4-wheel drive diesel, and 38" cut "Ranch King" to make side-by-side comparisons. But my expectation, based on seeing some other examples that were disassembled, is that the Gravely gear boxes are more strongly built than the others. My other riders, an Ariens S16-H with 60" mowing deck, a John Deere 317 with mowing deck, and Toro 322-D with 72" mowing deck all have hydrostatics. Every time I use one of them, I feel that I'm tempting fate as I don't believe any hydrostatic is comparably robust verses a good gear box. A great manual transmission in a car or pickup should run at least 1,000,000 miles without any more service than lubrication maintenance. The same cannot be said about automatics. I feel hydrostatics are comparable to owning an automatic car transmission. If you use it enough hours, it is likely to need much more expensive maintenance than a manual gear box.
I also have a Snapper 5-speed rider which actually has no gear box. Its motor spins an aluminum disk with a hollow center section. The 5-forward speeds are obtained by rolling against the aluminum drive disk, a hard-rubber-edged wheel on spinning on a 90-degree different axis. Its neutral is obtained by positioning the rubber wheel over the spinning aluminum drive disk's hollow center section. That way they don't touch each other. Forward speed selection just selects a linkage notch that moves the rubber wheel further from the spinning drive disk's center. Obviously, top gear contact patch is toward the outside of that spinning disk. Reverse is obtained by sliding the rubber power-collection wheel to the other side of the driving disk's spin axis. This configuration doesn't sound like it would be durable. Yet these goofy multi-speed drives enjoy a good reputation for durability.
One kind of hysteresis is internal friction with elastic bodies. Imagine how the rubber power-collection wheel is deformed as it contacts the spinning aluminum disk drive wheel's various selectable diameters. The rubber power-collection wheel is forced to deform more and more as lower speed ratios are selected. Consider how auto tires roll along straight roads without being forced to flex and squirm side to side. But when they are forced to turn from that straight line, it's directional path is continually changing until the new straight line path is established. During turns, auto tires generate lots of hysteresis internal friction. The sharper the turn, them more internal friciton. Snapper's rubber driven wheel is also subject to that same internal flexing. It converts part of input power to waste heat from internal hysteresis friction. The sharper the turn, the worse this friction becomes. Run a Snapper Rear Engine Rider in its "1st gear" position, and that little rubber power-collection wheel is forced to generate a LOT of hysteresis power loss because is is continually turning sharply. So this strange transmission's efficiency increases with every upward shift due to lower friction losses.
This may be more than you wanted to know about some of the many drive configuration options fitted to rider mowers. I have NOT described all driving systems I've seen or considered. Electric drives would probably be much more durable, more efficient, never leak, and provide other advantages compared to hydrostatic drives.
My personal order of preference would be:
Most preferred -continuously-variable-speed & direction DC electric drive
Next most preferred - All gear drives
Least preferred -
hydrostatic low-efficiency failure-prone often leaking drives
and
progressive mechanical-slipping variable-ratio drives like Snapper RER and variable-size pulley drives.
No transmission which converts a big percentage of input power to waste heat is a friend of mine. Others clearly are not offended by that kind of waste.
Others have their own preference orderings for their own reasons.
John
