The first thing that comes to mind is linkage adjustment. You may also want to check to see if all three of the small clutch plate rollers are present. Finally, you may want to check the detents in the clutch assembly to see if they are worn, in which case the rollers would not be able to remain seated within them when engaged.
FWIW, the clutch gap should be .050 in. at both clutch plate attachment points.
