Trying to crank the 812 today, the Direction Control Lever snatched back and slammed my wrist! and that was just the start of my troubles. The engine turns a little but bogs down quickly. the clutch plates spin together even though they are apart (I even backed them off further until I could easily see daylight through them), it pulls the DCL back until it catches on the seat, this is about the time that the engine stops its pitiful rotation. Gears are in N and pto is OUT. Any idea whats going on?
Gravely1964
Clutch bearing is locked on one side or the other
Gravely1964
are the bearings easy to replace or should i find a new assembly?
There not bad to replace. Remove the clutches and real easy you'll figure out which is locked
Thanks 1964, pulled it today ordered a new bearing, now just got to break this one apart....snap ring pliers, I know they're around here somewhere....
