1 - 8 of 8 Posts
A couple of years ago I upgraded my 812 with a Kohler M 20 Twin. After installing the engine I removed the 812's old wiring harness, ignition switch, regulator and I replaced it with the complete wiring harness from the donor tractor which was a 20G. It ran well until this past summer where I began to have intermittent ignition issues. I parked it and began doing my mowing with my L-8. I decided to fix the 812 and now I have no spark at all. Then engine cranks but has no spark. The magneto is good as If I unplug the kill wire at the magneto I can crank the engine and both plugs have a strong bright spark. With the harness connected I can crank the engine and have no spark. I have inspected every inch of the harness looking for any place there could be grounding. The harness has never been cut or modified. Nothing found. I replaced the ignition switch (P/N19233) with a known good switch (19233) and no change. All of the safety switches in the seat, PTO clutch lever and forward/reverse lever have been jumped and there is a verified complete circuit there. There is a relay (40216) and a time delay module (P/N 40313) that came with the harness. Could one or both of these have failed? This is the seemingly last place to look for the issue. Any suggestions on how I can further troubleshoot the thing?. Thanks.
I’d test the relay. YouTube has videos on how to do so. If it’s good, might be your time delay switch.
Thanks for the reply. I have a shop manual for the G Series tractors. Has everything I need to finish the troubleshooting. I pulled the relay and tested it and it appears to be good. I have not had time yet to go on to the time delay module. I am first going to check all of the interlock sites to be sure the switches (although I have them jumped) are functioning correctly and follow the checks right down the harness to the relay and time delay. We'll see.
Inveterate Putterer
I'm betting on the time delay module. I've had similar issues. I jumped the module and all was good - except no safety, which was not good. The replacement module is kinda pricey, even for used.
Gravely1964
They were around $100 or so the last one I changed at work. Im sure they've gone up in price
1 - 8 of 8 Posts
