1 - 7 of 7 Posts
Is there a good place to find parts? I need the steering gear as the middle 'teeth' have worn down. I found one on ebay for $100 but I was wondering if there were alternatives from ebay or CL. Thanks!
· Gravely1964
You can save those gears. Basically you have to grind it shorter on the bottom and add a washer or washers to the top and it will drive the mesh tighter if its the old style gears and not the box. Check out my vid and or the 68 430 thread on mtf here
Start at 4:53 ish I get into the steering
[ame]https://youtu.be/2fuqKcB_GoE?t=4m53s[/ame]
· Gravely1964
Thanks for the video! This is an awesome fix - going to give it a shot this weekend. Haven't grinded metal before but we'll see how it goes.
Main thing I will say is take your time and grind alittle at a time test fit. And try not to over grind, then have a whole bunch of washers top and bottom. But to fine tune it you can do that if needed
Unfortunately this did not work. The teeth were broken off and not worn down, so adjusting the height of where the gear fit into did not matter. I didn't notice until I had the part all the way off. Looks like I'll be going the way of the $100 used gear on ebay.
1 - 7 of 7 Posts
