1 - 1 of 1 Posts
Precision Application
DICKEY John GAC 2100 Agri Moisture Tester
Economical Accuracy
When it comes to top-of-the-line grain testing at an economical price, look no further than the GAC® 2100 Agri DICKEY John Moisture Tester.
The GAC® 2100 Agri provides grain testing results in just 32 seconds and has the ability to store eight grain calibrations.
  • Quick, fully automated grain testing
  • Engineered with advanced technology
  • Consistent moisture, temperature, and test weight results
  • Use for cereals, oilseeds, grass seeds, vegetable seeds, and beans
Product Specifications
  • Measurement Method: capacitance, Conductance, Weighing Device
  • Applications: Cereals, oil-seeds, grass seeds, vegetable seeds, beans
  • Measured Parameters: Mositure, Temperature, Specific Weight
  • Moisture Range: 5 to 45% (depending on grain calibration)
  • Grain Temperature: 0 ° - 50 ° C (32 ° - 104 ° F)
  • Temp Difference: 20° C (room to grain sample)
  • Temperature Compensation: Yes, Automatic
  • Moisture Repeatability: .1% (depending on Application)
  • Moisture Resolution: .1% moistureGrain Sample: Whole Grain, pellets
  • Sample Size: 250 Grains (approximate for cereal grains)
DICKEY John GAC 500 XT Grain Moisture Tester
The Power of Elevator-Quality Testing on Your Farm
This compact, cost-effective DICKEY John unit lets you analyze grain moisture, temperature, and test weight anywhere on the farm.
For fast, accurate moisture testing, you can't beat the GAC500XT Just choose a grain, load the hopper, and press a button.
  • Easy to use
  • ±0.2 moisture repeatability
  • Cereals, oilseeds, grass seeds, vegetable seeds, beans
  • Stores up to 16 calibrations
  • More than 450 calibrations available for download
  • 110/220 volt, DC converter, or cigarette lighter power sources
  • Preloaded with 10 languages (others available)
  • Measurement method: capacitance, conductance, internal scale
  • Moisture range: 5-45% (depending on grain calibrations)
  • Grain temperature: 32-122° F (0-50° C)
  • Temperature difference: 36° F (20° C) instrument to grain sample
  • Temperature compensation: automatic
  • Moisture repeatability: ±0.2% (depending on application)
  • Moisture resolution: 0.1% moistureGrain sample: whole grainSample size: 250 gr. (approx. for cereal grains)
  • Display: LCD (128 x 64 pixels)
  • Height: 13.5 in. (34.5 cm)Width: 10.25 in. (26.5 cm)Depth: 13.75 in. (35 cm)
  • Weight: 13 lbs. (5.78 kg)
  • Measured parameters: moisture, temperature, test weight
  • Calibrations: 16, user defined
Shop <a href= rel="nofollow">DICKEY-john
1 - 1 of 1 Posts
