1 - 1 of 1 Posts
Precision Application
DICKEY-john GAC® 2500-AGRI Grain Analysis Computer
Elevator-Quality Testing on Your Farm
DICKEY-john, the worldwide leader in grain moisture analyzers, offers the GAC® 2500-AGRI, an affordable moisture tester that provides elevator-like results.
  • Easy-to-use, intuitive color touchscreen eliminates operator training
  • Accurate temperature-sensing capabilities allow you to measure frozen and hot grain
  • Memory storage for up to 3,000 measurements
  • Multiple USB ports on the back of the unit for software upgrades, USB devices, printer and peripherals
  • Additional USB ports located on the front of unit for easy calibration imports, as well as keyboard and mouse plug-ins for inputting set-up data
Technical Information
  • Operating temperature: 36 to 113°F (2 to 45°C)
  • Power: 110/220V, 50/60 Hz, 30/35 VA
  • Humidity: 20 to 90% noncondensing
  • Grain temperature: -4°F to +113°F (-20° to +45°C) depending on grain calibrations
  • Storage/transit temperature: -4 to +140°F (-20 to +60°CMoisture range: 5 to 45% (grain dependent)
  • Approximate Weight: 25 lbs. (11.43 kg)
  • Approximate dimensions: 17”H x 19”W x 14”D (43.18cm H x 48.26cm W x 35.56 cm D)
Shop Grain Moisture Testers @ Agrimart.net
1 - 1 of 1 Posts
