1 - 9 of 9 Posts
What is the GPM and the max PSI of the Eaton 12 Hydro. I am looking into building a FEL for an 1886.
Your best bet would be to run another pump off like the motor.
:ditto:
I would set a pump off either the motor or pto.
Here are specifications for an Eaton 11 from a Wheel Horse manual. Reading the specs, I would say the max reliable output is at 3600 rpm input, 1.4 GPM at 700 PSI.
Didn't Cakes build a complete FEL? Yeah, here are the threads 1 through 5. I think I read in there the unit ran at 1200 PSI with a pump off a PTO belt
http://www.mytractorforum.com/showthread.php?t=84910
http://www.mytractorforum.com/showthread.php?t=86502
http://www.mytractorforum.com/showthread.php?t=88210
http://www.mytractorforum.com/showthread.php?t=90615
http://www.mytractorforum.com/showthread.php?t=104334
http://natecrosby.com/andy/WHorse/ea11wh.pdf
SPECIFICATIONS
TRANSMISSION: Eaton Model 11; Radial, Ball-piston
Displacement:
Pump and Motor with Auxiliary Charge Pump.
Pump, Variable 0-1.10 cu. in/rev.
Motor, Fixed. 2.09 cu. in./rev.
Input 3400 RMP
Torque Output (Max.)
Speed (as used):
Output 0-1750 RPM
Continuous 360 in. Ibs.
Intermittent 540 in. Ibs.
Maximum Continuous 18OoF
8” Diameter Fan Plus Oil Flow From Charge Pump
10 Micron, Full-flow, Spin-on Type
3.8 GPM Free Flow
1.4 GPM @ 700 PSI
Operating Temperature:
Cooling:
Oil Filter (as used)
Charge Pump (3400 RPM Input)
TRANSAXLE: Wheel Horse;
The eaton 11 is not the same as the eaton 12.
I thought about a building a real light duty FEL running off of the charge pressure. I don't see why 1" bore cylinders wouldn't work.
fred can,t you just hook up a snow plow pump and controls off a junk pickup.my 72 dodge power wagon had a pump and controls that should work.bought that truck brand new in 72.5,750 dollars.plow and all.how much are they today.
Deceased October 2017
Fred
I have never done it .. but the Duffs (Easton 12 experts) have a loader running off of the existing pump .. You may want to call them about it ..
I saw their loader in person .. So I know it works .. just not sure how well
Discussion Starter · #9 ·
Fred
Somewhere I will find the specs on the Eaton 12. Thanks for the tip Ken.
1 - 9 of 9 Posts
