Last year I did some work on my 1993 Troybilt Echno horse (6hp) Tecumseh H60 engine. I rebuilt the carb and ran new fuel lines. I did a bit too much disasebly and unhooked the linkages for the carb taking off the shrowd.
so I had it working last season, but had to use the throttle to control engine speed manually. the govenor was not speeding up/slowing down the engine as you started/stopped tilling.
I could have not gotten the linkages in the right holes, but I thought i did. or perhaps i have to litte or to much wrap in the spring (throttle?).
If i manually pull the govenor lever it moves easily and speeds up the engine so that is not frozen, it just isnt get enough pressure to move it easily.
Anyone know what holes the linkages should be in? Any ideas what to adjust?
Thanks, Pat
Thanks, Pat
