Hey guys, I got those two "V-engined" Toro's. They are both model 20442's. They are a little wore, but still in good condition. So far, I got one running. I had to put a Lawn-Boy primer bulb setup on it for now, as the orignal primer bulb was cracked and wore. Also, the recoil rope was short, so I put a handle on that anyways. I put some Lawn-Boy Generation 2 32:1 gas/oil mix in the tank, primed it a little, it fired, but stalled out. I continued priming it and trying to keep it running by using different positions on the throttle (slow/fast/choke.) After a bunch of primes and some pulls of the rope, I had it running and smoking! I ran it for a bit, and mowed with it a bit and I am quite impressed! As for the self-propel, it works great and I like the one speed transmission. When warm, it will start on one pull! And I said I hated V's! I got it to run, now all I have to do is keep it running correctly, but for now it is great! (Knock on wood!) As for the other, it needs a new bail cable. Eventually, I will need two new primer bulbs, two new recoil ropes, and another bail cable. And, both might need a carb cleaning as well as a port/muffler cleaning soon. Here are some pics for you guys.
