My older brother helped a friend clean out his cellar,and they came across an old snow plow for a Craftsman lawn tractor--model # 486.254071-KBGE....
...looks like the one I had awhile back that I think fits the silver 80's "LTV" type lawn tractors...it has a "C" channel with a 1" rod welded across it for the push frame,and the plow wasn't used that much,judging by the lack of wear and rust on it--had a slight kink in one side my sledge straightened out in a hurry!..
I was in the process of adapting a plow/bucket onto my Suburban I made out of a John Deere blade that I had used previously on my Yard-Man,and I got the thrust bars finished yesterday,and the winch mount that slides into the mule drive slot..still have a ways to go before I can use it,still need to wire the winch up,mount it,etc...its disgusting to see how fast the 4 hours between noon and 4 pm fly by this time of the year!..feels like I spend hours working and accomplish nothing!..
While I had the thrust bars I made that pin to the lower tabs on the front axle and run back to the rear deck/snowblower mount,I slid the c-channel from this plow under the tractor to see if could be adapted ---and I found it will be pretty easy,I used a pair of U-bolts (AKA as muffler clamps!) to attach the 1" round stock cross bar to the square tube bars I made from street sign tubing ,and it appears it will clear the steering linkage just barely,so that made me feel good,that I have the choice of using either plow setup--this one has a single coil spring so it can "trip",where as the J-D blade on the plow scoop thing is a solid one that wont give any if it strikes an immoveable object...that one will get the most use in slushy icy snow,when the plow with the spring might flop over too easily...the Craftsman blade is much thinner than the J-D one and I think if I bolted them both together,they still would be less rugged than the factory plow that came with one of my Suburbans!..
Now,if I could only eliminate the "weak" half moon shaped peice that always tends to bust on the Suburban plow before I ruin the existing one somehow..dont appear easy to make a thicker one fit or work using the factory latch setup..for now,my vise grips on the angle lock pin seem to be working to prevent it from angling itself as I plow!...
