Tip#1 - Subframe to bear against the rear axle.
Tip #2 - Subframe to be fastened to the frame over the front axle.
Tip #3 - Load the rear tires with RimGuard.
Tip #4 - Use the posts for the hydraulic oil reservoirs.
Tip #5 - Make the bucket wider than the tractor.
Tip #6 - Do a search at the top of the page for threads pertaining to "FEL", Front end loader", and "Loader" builds. There is a ton of info available.
Tip #7 - Have deep pockets. The steel is the cheap part. Hydraulics are expensive.
