Oh... I will. I will. :greendr:NIIIICE... Have fun!
yep! trust me- it will slice through grass like butter! If you have a lot of clay or hard pack it may be more work...muwaaahahahahahhaaaa!
Question... I've got a turn plow with my 12.. should I start off with the turn plow on virgin ground?
oh awesome!!!!! I'm on that like white on riceyep! trust me- it will slice through grass like butter! If you have a lot of clay or hard pack it may be more work...
I have a really good manual for a 8" turning plow at www.mediafire.com/GT_80
- it tells you how to set the plow, how to sharpen it, and how to maintain it- you should download it!
Do you have a culter on your turning plow?oh awesome!!!!! I'm on that like white on rice
I do have clay, but I don't think it is compacted too much. It was previously a garden area - several years ago. It is very thick grass now.
nope. got this one from Hugh, his has it mine doesn't... doesn't seem to need it really.Do you have a culter on your turning plow?
Its a little disc that cuts the sod before it gets to the plow.
im taking mine off for the plow day. the coulter wheel only helps with sod or grass or something like that. we will be plowing a field that has only ever had field grass, so that would have gotten clogged in the coulter. ill bring it anyway though, ready to be put on just in casenope. got this one from Hugh, his has it mine doesn't... doesn't seem to need it really.
tolland, ct! youre more than welcome to come check it out :trink39:Where is the plow day this time? i maybe will go next year if my van is up and running and i find a nice trailer to move my tractor with. i just loaded my tires with window washer fluid (23x10.50x12 tires) i got 8 gallons per tire and boy do they weigh alot and i need to put the chains on soon.:050::bellyemot:bellyemot:050:
YEP I've got the wheel. Most of them are all taken apart - so I've got to put it all together to see exactly what I haveDo you have a culter on your turning plow?
if you put up some pics, we can help :fing32:YEP I've got the wheel. Most of them are all taken apart - so I've got to put it all together to see exactly what I have![]()
:ditto:if you put up some pics, we can help :fing32:
YAYYYYYYYYYYYYY - I will do that tomorrow. We'll have a party:trink39::ditto:
