Geet Fuel Systems
The Global Environmental Energy Technology also known as the plasma reactor is a fuel system that was created by Paul Pantone. The GEET Fuel system is a vapour plasma unit that breaks or cracks the molecule of the fuel. This gives the engine better combustion efficiency.
Working of the GEET Reactor
The GEET plasma reactor motor makes use of water and other liquid for power. The engine runs on 80% water. The technology helped to save money and promotes a greener form of energy. The motor can be fitted to a car or any motor engine. The plasma reactor with use 50-80% of water or liquid and the remaining is gas or any burning fuel.
As our readers know only too well, Paul Pantone and Molley Pantone are the brains behind Global Environmental Energy Technology, popularly known as GEET, that saw the introduction of an innovative technology called Small engine plans. The motor can be built even by regular school students, having just a slight knowledge of the basics of mechanics. Safe to say, these students can choose to build it as a weekend project and complete the task within that period.
The technology can convert small gasoline stationary electric generators ranging to 10 KW. In simple words GEET is a fuel processor and is a simplified Plasma Reformer. It processes hydrocarbon fuel or waste and converts it to a form of Synthetic Natural Gas, that contains high volumes of hydrogen.
The parts from be procured from any hardware supplier as most of the materials required are plumbing parts. Some of the benefits of GEET include multiple fuel compatibility and more than ninety-nine percent lower emissions with a sizeable increase in the run time. The technology can be fitted into any internal combustion engine like turbine engine, gasoline or petrol. There are larger versions also available where the technology can be used for big cars and trucks.
The technology proposed by Paul Pantone was well within the ambit of thermodynamics rules. There are over 70 similar phenomenon available in rule books which become the source of the invention. To make it simple, the motor transfers exhaust heat to the fuel vapor, kept in vacuum and the overall configuration promotes a molecular breakdown inside the vacuum of heavier elements. Therefore, resulting in speeding up the molecular breakdown and intensifying the vacuum using less heat.
The Plasma Unit generates electrical fields while operating and some of these have opposite direction and are affected by mass movement of the gravitational field of earth, and that the frequency and vibration determine the amount of energy developed. Research laboratories in Europe have helped to duplicate the unit for the purpose of demonstration. Paul has also stated that non-natural heating can lessens the fields that are otherwise not normally self generated.
(The motor can be built even by regular school students).
Nope not here. But go ahead and build one. Let us know how it works out. Hardware store parts and a week end.
