Gear Oil Recommendation for BX Tractor
3573 Views 4 Replies 4 Participants Last post by  fastvance
Probably a dumb question, but...
For the MMM gearbox for my BX tractor, my manual calls for SAE 90 API GL5 gear oil in all seasons.
At the auto parts stores, I can only seem to find multi-grade oils like 75W-90, 80W-90, etc. Can I use one of these, or do I need to keep looking for the 90W? What do you guys use?
Thanks a bunch!
I used the readily available 80-90.
it`s a gearbox, don`t sweat the details.
I'll second that motion....Kubota dealer sold me Tutela Hypoide EP 80W-90.
Bryan
I wouldn't be too quick to downplay the importance of manufactures' recommended lubes because it's 'just a gearbox'.
Just as with an engine, often a range of viscositys are acceptable depending on the operating temperatures. 80W-90 will flow like SAE80 while cold and like SAE90 once warm and should be fine in the gearbox, 80W-140 however is too thick... just a little FYI.. :)
I too use the 80W-90 for the MMM gearbox. Just remember that gearbox's input shaft is turning at 2500RPM, too thick of oil will build up excessive heat fast!
Thanks for all your feedback, guys! I stopped by O'Reilly's today and picked up some 80W-90. In general, I try to treat the manufacturer's specification (for any kind of machine/vehicle/appliance) with the utmost respect (I'm a design engineer, too). I probably get a little too anal sometimes. :)
