Those gaskets are available from the dealer. I got my last ones from Messicks.
my thermostat had moved up into the top hose of radiator stuck sideways looked like a butterfly valve the way it was in there, anyhow when i replaced it all i had a 195 degree thermostat it seems to now run a little cooler.I started to tear down my 1950 Farmall M... Named him "Mo"... As I'm in the process of removing the radiator, I was shocked to find out that it did not have a thermostat or thermostat gasket. I went down to the local gas station and talked to some of the old farmers... Come to find out, thats a common thing around southern Indiana.. ANYWAY... I pulled the water pump to help with the removal of the radiator. When I pulled it off the block, the gasket crumbled into 3 or 4 pieces... Just wanting to know what I should use for material to make a new gasket... Cork?
Thanks in advance...
