You can convert a small electric compressor to gas by just changing the electric motor to the gas engine and using an electric clutch on the engine.
You need a gas engine with a good governor and a throttle you can set to maintain the engine speed.
Wire the existing pressure switch to engage and disengage the electric clutch the same way it started and stopped the electric motor.
The pressure line coming out of the compressor to the tank already has a pressure unloader valve in it so the electric motor didn't start under pressure.
The disadvantage is the gas engine has to run at a higher RPM all the time whereas the Granger valve allows the engine to idle when not driving the compressor.
I've seen the Amish redo small compressors this way and they work good for small jobs.
