Gas Cap w/ gauge; quarter turn
919 Views 3 Replies 3 Participants Last post by  tracktortag
Just ordered the second gas cap w/ gauge off e-bay.
https://www.ebay.com/itm/NEW-QUARTE...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Seals tight w/ no leakage and you can view gas level without opening the tank.
I know it's not exactly proper and stock to the tractor but it works great.
Depends on the tractor model.
Definitely won't work on a G series, as those are threaded caps and the tanks are deeper. I've never seen an aftermarket replacement for them.
Sent from my SCH-I605 using Tapatalk
Should have added that these fit the Model L tractors w/ a quarter turn tank cap, sorry.
The company that makes these, Kelch does make a threaded type so you would just have to match up the depth to work on the later models.
My 816 came with a quarter turn gauge cap. It doesn't have the raised cap in the center. I guess that would be a vent cap? The only other difference is that it measures 12 1/2 inches. It has been accurate, the float has never hung up, and I like being able to see the fuel level without having to guess, or open the cap, as you mentioned.
