My Snapper is equipped with the 42" deck. Lately it has not been leaving a smooth cut. It appears to be leaving ridges or narrow stripes in the grass. I cleaned out under the deck, but the main grass build up was between the blades.
I noticed that while rotating the blades by hand, that there appears to be about a 2" gap between the blades. Yet if the blades were any longer, they would scrape the sides of the deck. Is this normal for this machine? My Craftsman has 3 blades, yet there is only about a eighth of an inch gap between the blades on it. Any experienced opinions would be appreciated.
Could the blades have encountered anything that might have bent them? As far as the gap is concerned, most multi-bladed decks have the spindles located so that the cutting paths 'overlap' in the direction of mowing to prevent 'holidays' between the blades. I've found 'stair-stepping' cut levels to usually be caused by uneven/out of spec deck height issues. Spindle end-play & spindles not perpendicular to decks are also possible, but not as likely.
i know mine come with in a hair of hitting but they are staggered to like the front one is a little farther front than the back so really the blades overlap by some.... sorry if that sounds crazy
Did you install or have installed the current blades? or did the problem just appear? The 42" RER uses 2 21" walk behind Snapper blades,some one could have used shorter blades,I'm not an expert on walk behinds, but I think there is also a 20" blade,so using them would give you a gap.
