1 - 3 of 3 Posts
For reasons known only to me, I want to take apart an 800/8000 fuel tank along the middle seam.
Does anyone know is that a brazed joint? I've been assuming that and will attack with the OA torch and compressed air to see if I can blow it out. Only other way I could imagine that joint being made is some kind of press/friction weld but that doesn't seem likely.
BTW, the valve insert had solder between it and the tank bottom to seal it. Is that normal or a fix after the tank previously had a hole brazed in it?
Thanks,
Scrape the paint down on a seam, the color of the metal in the seam should answer your question.
Roger,
P.S. I think the halves were soldered together. Silver solder or lead, well consider the age?
Brazing requires heat that can melt most sheet metals.
All fuel tank used to be soft soldered then semi automatic welding was used.
Be very careful when soldering with a flame. Make absolutely sure that the all gasoline fumes are gone. It takes a lot of water and detergent and shaking to get rid of it all.
Gasoline liquid does not burn, the fumes do.
You can use any solder that you want. 50-50 or 60-40. Just make sure that the steel is absolutely clean. The slightest amount of corrosion and the solder won't stick. Soldering acid helps to clean the steel. I would use some muratic acid as a prep.
Richard - who has patched many a tank by soldering a penny over the hole.
1 - 3 of 3 Posts
