1 - 7 of 7 Posts
The fuel tank on my 3000 series has developed a leak where the low fuel sensor enters the tank. Is there a replacement grommet for the low fuel sensor?
The parts diagram I am looking at does not show a grommet for the low fuel sensor. This is the second time this leak has appeared. The first time I ended up replacing the entire tank, mainly due to an unsightly and unsuccessful repair attempt.
Is there a realistic way to repair the tank, keeping in mind I can replace the entire sensor for $34.00?
Thanks in advance,
Doug
BUMP... Have this same issue with my GT3200.
Is this a common problem and is there a part number or specific gasket for this repair?
Love my GT3200!
Rob
Ocklawaha FL
mowing 4 acres
2464317
Thanks in advance,
Doug
Love my GT3200!
Rob
Ocklawaha FL
mowing 4 acres
I sealed my 3240 up with these two grommets/seals
  • Like
Reactions: Joelk
GREAT! I’ll check these out, thanks :)
Thanks in advance,
Doug
Where can you get the entire sensor for $34?
I have used:
While you are in there, install one of these(fuel pickup grommet):
That post was from 2011. I don't know the part number to look it up, but maybe pricing was different back then?
Thanks! I did not notice that it was posted over 9 years ago.
The PN is 751-3161 and they cost > $50 now, so apparently there have been some major price increases.
If I could buy new for $34, I would buy some.
1 - 7 of 7 Posts
