fuel filter on yanmar
696 Views 6 Replies 5 Participants Last post by  mrbeef
going to change the fuel filter and was wondering if there is a particular process
to bleed the air from the system. tks in advance for any help,
Jimmy
1 - 7 of 7 Posts
Jimmy
Star the engine and run it about 30 seconds, then shut it off. There is a fuel shutoff at the filter bowl; turn it to shut the fuel off. Use channel locks to loosen the ring at the top of the filter bowl, then pack rags down on top of the flywheel guard to catch spilled fuel. Unscrew the ring and pull lightly down on the bowl. The filter will stay in place. Empty the bowl, remove the spring and water ring and clean the bowl. Pull down on the filter to remove it, and push the new filter in its place. Make sure the spring and water ring are in the bowl, then slip it up over the new filter. Thread the retainer ring hand tight, then snug it with the channel locks. Open the shutoff valve and let the bowl fill as much as it will. There should be some residual fuel pressure in the line.
Start the tractor, It will fire and run, then begin to stumble. It may or may not quit. If it quits, keep the throttle about 1/2-3/4 open and continue to crank for a few seconds at a time, it will eventually start, maybe run rough for a few seconds, then smooth out. The injector pump on these engines is self-priming, no need to loosen anything to bleed air.
sounds easy enough, I appreciate the help,
Jimmy
That is good to know. It really stinks to have to crack the injector lines to bleed out a Cummins. :tango_face_grin:
You just say Yanmar. What tractor are you talking about? I ask because my 430 (with a Yanmar) does not have a filter bowl as described above, so that explanation would not help you on a 430.
The procedure I listed works on any X4, X5, or X7 diesel. It also worked on my 1985 Yanmar 1810D I owned before my X7.
As mentioned model of machine might be a slight help. Also depends on how much air you allow in the system during the change. There are some older Yanmar powered Deere units that are not as easily self primed that newer units. My 455 and X748 have no troubles... I had a 430 that I had to crack the lines on.... Same with a 3215A fairway mower. Try the easy route first.
Sometimes it just seems like they don't want to prime themselves.... :ROF
1 - 7 of 7 Posts
