Hi Folks! New to the forum but have search your forum and found lots of help in the past!
Hoping to get some assistance with my 94 John Deere 445. Over the past few years it’s idle quality has decreased and now at WOT I can hear an intermittent miss-fire. I discovered the oil to way overfill (about 3/4” over the full dipstick mark) . While draining it it’s definitely badly fuel diluted.
It will run and mow eh “okay” but when you throttle it it will throw black smoke. Certainly over fueling for one reason or another
I have confirmed the left side cylinder to be a little weaker then the right as far as comparing engine rpm when removing spark plug leads. I understand this is normal due to intake design but its definitely intensifying the issue. I have swapped coils from side to side to rule out a coil issue. No beans.
I have around 190 psi compression on both cylinders, giceor take 5 psi. Confirmed valves to be properly adjusted, 26 psi of fuel pressure, recent spark plug and fuel filter change.
I have checked for vacuum leaks, I have followed the repair manual to confirm my coolant temp and MAP are within ohm spec. I also have my 5v reference on both of those s
I’m leaning towards a faulty/dirty fuel injector but if this was the case I’d think it would blow black smoke all the time?
I’m Kind of stump on this, I don’t want to throw parts at it. I’ll take it to John Deere before I do that!
If anyone would have some ideas I would reallly appreciate it. Mowing season it’s here in southern Ohio!
Thanks in advance
Thanks in advance
