1 - 3 of 3 Posts
My neighbors commercial Toro ZTR needs new front tires. Anyone have recommendations for brands of tires? It’s a full size 52” deck commercial and it weighs about 1400 pounds. Should I put tubes in them as long as I’m replacing tires? The lawn is a little bumpy as part of it was a farmyard decades ago.
tubes have their place but i recommend not using them. during mowing season if and when you have a flat you must dis assemble to fix instead of using a plug or slim. i know there will be others that prefer tubes. depends on how good you are at fighting small tire changes.
Choke's stuck on!
I've never had bad luck with any Carlisle tire. Reasonable priced, too. If your ground is at all wet, check out smooth tires vs. ribbed.
1 - 3 of 3 Posts
