Does this look good to you guys my front tires are robbing
it probably just needs bearing in the hub.The tire robe the metal a little above where the grease fitting are
You likely do have a bearing problem, although you can gain clearance by turning the rims....I did with the agr. tires..PITA to put air in though.[/QUOT
Will try that and check the bearings
