1 - 1 of 1 Posts
$889 mo FREE SHIPPING in the US (48 States) TRADES ALWAYS WELCOME. I'm Sean and I’m Here to Help! Call, text, or email me 24/7 directly for more information – 602-753-9611 Arizona’s #1 Tractor Dealer – TEAM TRACTOR and EQUIPMENT - 21427 N Black Canyon Highway, Phoenix, Arizona 85027 (I-17 and Deer Valley) www.TeamTractor.com
Finance at $889 month – FREE SHIPPING (48 states) - This is a Beautiful Crawler Dozer with only 1,764 hours; 72% Measured Undercarriage on Case Xtended-Life Tracks; No leaks in the machine; OPTIONS and EQUIPMENT: HD Drawbar Equipped; Optional Front Counterweight; HID Lighting; Dust-Master Dual element radial seal air cleaner; Case Electronic Power-Control System with Cruise Control, Auto Shifting, and Dial Variable-Speed Travel Control; New Cutting Edge being installed. This is a well maintained and cared for a low-hour dozer that is Available for SALE or RENT-TO-OWN
SPECIFICATIONS: OPERATING WEIGHT (as equipped) 19,879 lbs; ENGINE Case IV 445TAEG7A 81 HP Diesel; Displacement 274 in3 (4.5 L); Engine speeds RPM High idle – 2160, Low idle 950;
Radiator: Area 357.5 m2 Ratio 1.1:1; DRIVETRAIN Dual-path hydrostatic: Pump Variable axial piston; Motor Variable axis piston; Max. drawbar pull 36,110 lbs; Transmission Single lever control; Electronic Straight Tracking Control; Parking brakes Heavy-duty hydraulic pressure release;
Steering brakes Hydrostatic; Final drive 2 helical gear reduction planetary output Ratio 61:1; HYDRAULICS Pump flow @ 3,000 psi 20.3 gpm (78.8 L/min); Lift cylinders Two (2) Bore diameter; BLADE Variable blade pitch 52d – 60d; Lift speed – per second 19.7 in (500 mm); Cutting edge Reversible, replaceable Width 8.0 in (203 mm); Thickness 0.625 in (16 mm);
I'm Sean - I’m Here to Help! Call, text, or email me 24/7 directly for more information 602-753-9611 Arizona’s #1 Tractor Dealer - 21427 N Black Canyon Highway, Phoenix, Arizona 85027 (I-17 and Deer Valley)
SELLING PRICE - $63 650
1 - 1 of 1 Posts
