Everybody needs a carryall right? I have seen a lot of nice ones here and on other forums built around the TSC carryall frame or similar.
I already have a TSC trailer mover, so I thought I would try a receiver mount cargo carrier attached to it and see how it works.
I am not a Harbor Freight fan, but their aluminum cargo carrier had excellent reviews online. It lists for $129, is on sale for $99, and currently has an online $20 off coupon, so it is $79 plus tax.
It took me about 30 minutes to put together. The four sides attach to the frame with 16 hex bolts and nylock nuts. I used an 8mm nut driver and wrench to bolt the sides to frame. Per usual, it pays to put it together loosely before tightening everything down.
The corners bolt together with larger bolts and nylocks, you will need a 4.5mm allen wrench and 13mm wrench or socket, the same tools are used to attach the receiver sleeve to the frame.
The unit is very lightweight and easy to handle. It slid right into the trailer mover. You can see from one of the pics that if I grind just a bit off of the receiver, the cargo carrier will fit tight against the trailer mover. As it is now, it is about 4" from the frame when the holes line up to slide in the hitch pin.
It fits well, doesn't rattle, but you can wiggle it around a bit. My wife and I took turns lifting each other in the air with the hydraulics, no problems. I dropped a piece of scrap plywood on it, and I think it is ready to go. I will post more after I use it and customize it a bit (tool box, shovel holders etc).
