Ford lgt18h hydro problem
469 Views 2 Replies 2 Participants Last post by  pmm289
Hello all,
I'm trying to troubleshoot an issue with a 1989 lgt-18h with an Eaton 1100 and can't help but think I'm missing something so figured I'd see what advice you can give me.
While mowing, I all of a sudden lost pressure in the forward/reverse hydro pedals. Normally there is some resistance when pushing on the pedals but now there is none.
I figured it was a linkage issue, but can't seem to find anything broken externally. When putting the mower in neutral, I can push it around, and when putting it in low or high range, I can push it slightly but can feel the hydro give some resistance once it starts to move. The hydraulic lift for the deck still works as well. I checked the fluid level and it was a little low, so I topped it off. Was about a 1/4" shy of the full mark on the dipstick which didnt seem that low.
Part of me still thinks it's a linkage issue given the change in feel of the pedals and the fact that the hydraulic lift still works, but unless there is an internal linkage for the pedals I can't find anything out of place externally. Anybody have any advice or thoughts on what could cause this and what else I can check?
1 - 3 of 3 Posts
I dont know about this specific model trans but most have a release lever that allows you to move the tractor and also have a relief valve to relieve pressure if the pressure gets too high. It sound like pressure is being relieved someway. I would check to see if it has a relief lever that could have possible moved a little and allowing pressure to bypass or possibly the reilef valve has failed if it has one. I would try to find a hydraulic diagram to see if it has either of these. Wish I knew more about these trans so I give a more definate answer. Maybe someone that knows this trans will chime in with some advise.
I know there could be a release lever, but not that I am aware of. My assumption is that since it has a hi/low/neutral range, that neutral is used as a release lever. The thought that this could be broken crossed my mind, but externally the gear selector is working fine and I can tell the difference between neutral and putting it in gear.
There is a relief valve it seems. Looking at the manual it is internal in the Hydro, so not easily accessible. It consists of a ball and a spring, held in place by a screw in plug or set screw. Seems hard to imagine that coming out but anything is possible.
1 - 3 of 3 Posts
