1 - 1 of 1 Posts
Well folks I got a free LGT 145 last year... Most of it was in a box... here is a picture to remind you...
Now I didnt go overboard with the mods like my 165 :trink40:
- from Kirk engines
*Billet Breather cover
*Bosh Blue coil
*Pointsaver system
*Performance plug wire
- Local machine shop
* Balanced crank 53%
* Honed block .010 over
* Honed crank .010 under
- from turftractor.com ( stens parts )
* Piston
* Rod
* Valves
* Gasket kit
* points
* Carb rebuilkd kit
- from ebay
* Digital battery meter
I also loaded the tires with free junk yard prestone... I also removed all the useless wires... and there is alot of that... I bypassed the way the factory had the power thru the volmeter to start the engine... That is the stupidest thing I have ever seen... This Tractor came with a 52 inch deck... what a peice of junk its almost 67 inch wide to cut 50... and it dosent even do a good job at cutting... Not impressed... So I will be looking for another 42 inch deck for this baby...
For a free tractor I spent close to 500$ to fix it...
:fing32:
1 - 1 of 1 Posts
