1 - 1 of 1 Posts
Friends backhoe fried a wire that goes to the starter solenoid, it has been replaced with a new wire from the key switch to the solenoid, not sure if its related but the backhoe can start in gear. He's not sure if this was an issue prior to the burned wire to the solenoid or not, he could not see if the burned wire from the solenoid came from the neutral safety switch or not... So 2 questions:
1. The neutral safety switch shows continuity with key in "off" position, does that seem correct? I would have thought it would only show continuity with key in the "on" position.
2. Should the wire have gone from the key switch to the terminal on the neutral safety switch then on the second terminal on the neutral safety switch go to the starter solenoid?
1 - 1 of 1 Posts
