1 - 3 of 3 Posts
any one tell me what the lever under the seat does and how far should my brush hog lift and lower when I slid the lever on the right side?
The lever on a 6xx will look different but functions the same. 'UP' on the 6xx witl actually be horizontal and even with the cover.
to the original poster.. if your lift is not lifting as high as you think it is, then you may have cam / cam pin wear under the cover.
how high will the ends of the lift arms lift off the ground? 30+ inches?
soundguy
1 - 3 of 3 Posts
