I was working my 1970 4000 yesterday doing some bush hogging and discing. I had a little problem when lifting my implements. After about an hour of work, my lift would fail to lift up the implement or it would only lift it partially. If I turned off the engine and restarted it, then the lift would work just fine. This hapened once or twice more but seemed very randon. Its not a real big deal, but I am wondering if I am heading for a problem or if this might be a simple fix? Hydraulic fluids are fresh.
Have you checked the fluid level? Also, does it have a manual transmission or a Select-O-Speed? They used different hydraulic pump setups for the 3 point system and troubleshooting issues is a bit different between them.
Fluid level was actually a little high. I let it drain until it stopped coming out of the sight plug, but still seemed to have the issue once. It does have the manual high/low transmission with 8 speeds.
Sounds like the pump itself is starting to go. Does the PTO still work when the lift is having the issue?
