1 - 20 of 34 Posts
· One of few employed in MI
This is really dumb but I want to make sure I'm not going crazy. What is the shift pattern on a 3cyl diesel/6spd Ford 2000? The right lever when forward is low and backwards it high. The left lever is in an L pattern. If you pull it back it is reverse but then it gets weird. If I put in the center of the 3 forward speeds it just creeps along but it goes faster to the left and right. Is 1st in the center or is something FUBAR'd?
· Cal Fire Air Tanker Pilot
Center has always been Neutral on everything I owned. I would say FUBARed. Possibly a bent shift fork.
Discussion Starter · #8 ·
Ebay also has a Ford 2000 shift pattern decal for an 8 speed transmission. Is it possible you have an 8 speed transmission with one gear not functional??
No idea if its an 8. My only forward speeds are all forward with the shifter and there are 3 of them. Could be messed up but its been messed up since I started running the tractor.
post the model id code from the trans bellhousing, aft of the starter.
soundguy
I'll have to post that up tomorrow. I won't be able to make it over to the barn until tomorrow morning when I go to fix the muffler and grease the machine up. I'll also figure out exactly what way 2/3 seem to be.
Discussion Starter · #9 ·
Thanks for posting up about ebay! I just went and looked for those decals. Did find a bit out just looking at those. First off, you can tell I'm a newb with the older tractors because I thought 1/2/3 were all in low with either trans. I guess I have an 8 speed looking at those shift patterns though. I have to have a messed up shift fork or something because I get 3 forward speeds all forward and reverse is just below 1st/5th. Its not down in the center, its down all the way to the left. I know this is really confusing in writing but I'll take a video of it tomorrow and post. The second thing I learned was that my PTO speed is at 1800rpm. I've been cutting at ~1900rpm because it wasn't marked anywhere for 540.
*Edit* There was never a ******* 6spd in these tractors for a year or by some outside company was there? I just ask because it seems to shift just fine. Don't have to force anything and its not sloppy either.
Discussion Starter · #11 ·
If you have 3 gears across the top row.. i'd say you have to have an 8spd... i don't think your pto rpm is a big issue.. I cut between 1600 and 1900 rpm on my 5000 depending on the conditions.
soundguy
I don't think me cutting is an issue either. Was just curious on what 540 was on the 2000. Its about 1900rpm on my 1220 so thats where I was running it on the 2000. I'd assume I have an 8spd too if I have 3 across the top. Like I said, I'll take a video and post up showing the shift pattern.
Discussion Starter · #13 ·
Ok, I went to the barn to see about this whole situation today. I'm more confused than ever. The middle gear is definantly the slowest. The video was taken at idle but I went through all the gears in high and low. Speed wise, it still seems like its 213 BUT in the video you will see my new discovery. I played around a bit, changed the trans fluid, and played around a bit more. Its really seeming like 213 up top and RR down low. Just watch.....
pic
These are the markings I found in the general area you told me to look.
Just behind the starter
On the right side of the shifter
Under the seat (left side)
You have a Messed up 8 Speed Tranny. Your going to have to get a service manual for that thing and you might see the problem if you pull that top cover.
I'm thinking Shift fork or something along those lines.
Discussion Starter · #15 ·
I think at this point the job is above my head. I'm a car guy and love tinkering with tractors but its a new hobby. As dumb as it sounds I'm lost for the most part on the easy stuff. I can completely wipe out my computer on my car and reprogram it manually, but a 38 year old tractor dumbfounds me! :ROF
Maybe I can get someone on the board from the area to come help me.
AHH.. new piece of info!.. FFF and back is RR, and then you have a 2-spd range selector.
makes sense now...
6/4 manual reversing tranny!
Last letter in the model ID will be a 'K' for the 6/4 manual reverser.
soundguy
Outstanding piece of work! So this is a 6 speed forward and a 4 speed reverse transmission?? Must be designed for a tractor that does a lot of reversing??
Reminds me of the transmission designed for a French tank - one speed forward and 10 reverse!! Designed for a purpose!!
Discussion Starter · #19 ·
You're a god among men! You guys thought I was crazy but I knew I wasn't. Only took a video to show you! Is this a rare trans?
I never seen a transmission like that or even heard of one. I just buy tractors because I need them and sometimes work with them and repair when needed.
Family and employees mainly run my equipment on my farms, but I myself do all my strip sprays on a Ford 8N.
1 - 20 of 34 Posts
