Hi Guys, I'm new to this forum so hopefully I'm in the right area. I was asked by a friend who runs a christian camp to see If I could look at there ford 2000 hydraulics as they were not working full stop. Now I'm guessing most are going to want to know what model/year etc but the only numbers I can find don't match to what fords code system are. I'm looking in the right place and these are the numbers/letters I have.
1st set is hard to read but looks like this 6C47B
2nd set C216
3rd B*036928*
It's the 3cyl gas model
So far I Removed the top cover under the seat to remove the return and suction filters. (along with the skin off my knuckles) To get the suction filter out I had to split it in half as pulling out the pto inspection plate was no help. The filters were completely blocked with sludge due to water being in the oil. I have replaced the filters and put new oil in that meet the ford specs from mobil. Also removed two plugs on the pump hoping it just needed priming but with the tractor running no oil came out. I'm hoping it's not a pump issue as they dont have much money to spend on it.
Now what I'm guessing is the 3x5 plate that sits on the top cover looks to maybe have a old spool valve in it.
Any other thoughts on where to next would be much appreciated. Thanks Rowan
2nd set C216
3rd B*036928*
