1 - 11 of 11 Posts
Hello folks,
I have a 1986 Ford 1710 tractor, a sweet little machine except for one thing, it has manual steering. Is there a retrofit kit for installing power steering on this model or some other method of getting power steering? I love the tractor except for the manual steering.
Thanks in advance for your advice.
Roy Hill
Are you sure that it's manual??I've got one also,and it's termed "power assist" steering.Not your regular power steering by any means.To make things worse, it has a FEL which makes it even more like manual steering.My old Ford 2000 HAS power steering,and it is a dream compared to the nightmare of power assisted steering.Check your manual. It'll show you the difference.
Carrie
according to cnh, there was manual and power stering.
PS columns appear under the following assembly part numbers:
SBA334010590
SBA334010620
SBA334010870
manual columns:
SBA334010630
SBA334010610
I guess you could find a donor tractor and swap parts.. otherwise it would be pretty expensive to buy new.. if all the parts are available. etc..
soundguy
Thanks for the comments.
Yeah, its manual steering alright. I have a repair manual and an operators manual and they both show a 1710 with power steering and one without. I tried all my local contacts with tractors and they couldn't come up with a good solution either. I guess I will just keep the tractor and learn to love manual steering.
I do appreciate the response. Maybe someday I will run into someone that has a junker with good power steering parts.
Have a great day.
Roy H :thanku:
As one side idea.. you might contact jackson power steering and see if one of their units will fit your machine..
soundguy
Thanks soundguy,
I just sent them an email. I didn't know about that company. I just might get lucky.
Roy H :thanku:
good luck.
many times if they don't have a template for your tractor.. they might at least help you with parts.. etc.
soundguy
Discussion Starter #8
Jackson Power Steering don't have the kit fot the 1710 yet but he has it on his "to do" list.
Thanks Soundguy for the information, I will keep his web site and check with him later on his progress.
Roy H
Discussion Starter #11
Thanks guys, I'll try those links for used parts.
Roy Hill
1 - 11 of 11 Posts
