so i went to replace the tail lights on the 300, but ya gotta paint it first right?.....
Thanks for that tip KATT, my dash panel looks pretty ratty, was going to buy new but i think I'll give it a try.:thanku:FYI I use a felt auto touch up pen ( silver in this case) to restore the grill emblems and raised dash-board Icons.
The dash icons had NO paint left on Rusty when I got him.
Great tip. Thanks... took a q tip and put a coating of vaseline on the white letters and sprayed it with gloss black paint
Looks awesome!! Did you spray in your garage? I don't see any overspray... Did you use HVLP?ahh, theres that fine coat of JD green!
yep, spryed in garage and yep got a little overspray even with the hvlp i used. got some on the tractor that will clean up but more work, the overspray that hits the floor you can just sweep and blow it out the garage. this is what happens when you forget to cover things up....Looks awesome!! Did you spray in your garage? I don't see any overspray... Did you use HVLP?
yo Katt, what about this ratty thing, your saying "silver" is the color for the dash icons right? need to replace the foam padding too, any idea where to look for that?FYI I use a felt auto touch up pen ( silver in this case) to restore the grill emblems and raised dash-board Icons.
Black Garage door bottom gasket?... need to replace the foam padding too, any idea where to look for that?
