Here are a couple more pics that I had posted on the other forum. The tiller does a really nice job, I was really surprised at how easily it turns the ground over.
I've used the box scraper quite a bit now and I'm very happy with what I can get done with it. I can rip hard ground up with 3 teeth extended OK, but if I only put 1 tooth down it can dig real nice. I'm sure a bigger machine can cut a lot deeper, but I'm happy with what I can do. Once I add a bit more weight with wheel weights and switch to ag tires it should be even better.
Does anyone know what the lift ability of the 3 point is on the 3000 series? I haven't been able to find the spec anywhere.
Ducati: I was also wondering if your snowblower attaches to the front splines of the PTO? I'd like to see some closeups of how that attaches if it does, I want to fabricate a mount for a hydro pump up there.
I haven't gotten the reverse problem corrected yet, but I'm convinced it is just an adjustment. I talked to the dealer about it and they are going to fax me a diagram that shows the adjustment. If I can't get it, they'll adjust it when they deliver my mowing deck.
This pic shows the hydro pump mounted under the machine:
This is a pic of the pump itself:
Here is a pic of the tiller hookup to the 3 point hitch:
