it's a 8n,
it's to new to be a 9n!
8N debuted in 1947
8N debuted in 1947
Its a 8n for sure. Sombody at one time put 9n front hubs on it. Couple ways to tell if its an 8n, "ford" script fenders and hood, draft control lever under the seat area, no ferguson system emblem under the ford emblem in the front, side mount distributer, 8N in the beginning of block casting number, has a little vent door on the right (passenger) side of tractor hood, etc. #1Aluminum pistons or steel, i would probibly think aluminum pistons, unless it was rebuilt with a different rebuild kit with steel pistons. #2 Well if you are going for what was originaly used, In my original manual it says use S.A.E. 30 for temps above 90 degrese, use S.A.E. 20 for tempratures between 32 and 90 degrese, use S.A.E. 20W for temps between 10 and 32 degrese, and use S.A.E. 10W for temps between -10 and 10 degrese. But now days they have multi-grade oil so somthing like 5W30 oil would work just fine. Any more questions just ask.:fing32:Found a 1947 8N while snowmobiling, I talked with owner gave him some $ and now I'm owner. It has not run in roughly 4-5 years. Was not able to turn over by hand, Engine may be stuck, (pulled the plugs and loaded it up with PB Blaster) was what I had at the time. OK Question 1- does this engine if all orig ? have steel pistons versus Aluminum. 2- I've bought some manuals, none state what oil should be used in this engine. 3- everything number wise that I find on the tractor says 8N and it has a 4 speed trans, but the front wheel hub has the Large bolt pattern and some folks are telling me it is a 9N because of that, my numbers say 8N6007 and it has the 8 bolt rear, I'm pretty sure it is a 8N, what would be a good rust eating oil to break it free ?:dunno:
Thank you for the info, I too have had good luck with interstate before. what is a dealers name that mite have them in stock for a N model. Does TSC carry the interstate brand ? going to an Auto parts store for something of that age & 6 volt, they just look at you kinda funny.Both of my current N's are 6 volt. Properly maintained they are just as good as 12volt IMO. TSC has reasonable 6v batteries but I have better luck from Interstate. a bit more $ but I get a lot more life out of it.
Big +1 on this, this is the quickest way I know to get at a front mount.Pull the plug wires from dist, remove two bolts holding it in and slide the dist out. It will only go back in 2 ways, one is right. As long as the dist fits flush it is right.
