3601 - 3620 of 3627 Posts
Parts collector
We have trees around here that were "blown" over too from the storm yesterday. Nothing on my property but up and down the road. power went out too.
Going to get pressed into service today. The neighbor has a heavy leaner box elder that split about 15' off the ground and fell to the ground. I am not wild about doing chainsaw work this time of year but it has to be done. Will take the orchard sprayer off the bucket tractor, as the loader makes life just a bunch easier. Burn pile is 100' away. Will cut the big limbs of the tops and pull the whole thing to the burn pile which we will start and burn as it gets cut up. Then use loader to cut trunk into manageable pieces and dump on pile. Should go pretty fast as it is only a 24" tree. All the saws are "summerized" except two which are always fueled and ready to go, a 346XP and 357XP, my favorites.
Got all the work above done today, took 2 hours including cutting stump off low but haven't got Tordon on it yet.
I am making this post because I screwed up today and it could have been much worse hurting myself.
The injury is a slight skin tear the size of a dime above my left ankle and a contusion that caused a bruise. Here is what happened:
The crown of the tree is on the ground attached 15' off the ground. I always cut all the the limbs off that are touching the ground and in big pieces because I am going to pull them to the burn pile with the bucket tractor. I had finished left side of the tree and was on the right, the tree at this point had probably 2 or 3 points touching the ground but it is hard to see with all the leaves and brush. EVERYTHING you cut has some amount of tension or compression and I am very cognizant of this. I was cutting an 8" limb with a LOT of weight driving it into the ground. A shallow cut was made on the top, then 2/3rds of the way through was cut on the bottom towards the top but a small amount was still attached holding it. I made several more very shallow cuts at angles so as to not stick the bar and did cut through the branch which I felt would go directly to the ground. But it did not, it when horizontal to the ground and hit me in the leg, hurt like a [email protected]@rd and really startled me.
Right now as I am typing, I still don't see what I did wrong other than not understand what force caused it to do that.
The tree being a heavy leaner was felled with a bore cut that was without issue. I don't bore a lot but the tree already was split about 12' in the middle 15' off the ground and was a very strong barber chair candidate.
Anyway boys, I screwed up. :rolleyes: :censored:
Glad you are mostly OK.
Have Dog - Will Travel
Discussion Starter · #3,605 ·
Heal fast Ron - and chalk this up in the contuse and learn column.
Dodged a bullet there. Glad you're still ok enough to still be here to talk about it!
You're not kidding, this is always a dangerous job. Nothing worse than not being able to learn from it, either (not knowing exactly what you did wrong).
Mike
Glad it was minor...incidents like that always make me more careful the next time...,,heal up quickly...tree work is some of the most dangerous work there is
Mike
Thanks guys, I am fine and will walk 18 holes in a couple hours as I do everyday since I never get a day off like the working lads.
Just posted to instill safety in everyones minds.
Last week another neighbor had a 12" limb break out of a cherry but it was still attached 20' off the ground and land on their shed. They wanted my opinion. I said, "take pictures and call your insurer."
Good call! I won't cut anything that has enough height to hit any nearby building. Unless I rent a lift, and even then, I'd prefer not to. And if something is already half down and leaning on a building, I'm definitely not touching it...
Mike
Well this doesn't look firewood related but it certainly is.
My logger buddies were here this morning to pick up 3 bushels of Honeycrisp I had for them. They weren't working due to the rain today. In the truck they had the door off the log skidder that had one side of handle broken off completely due to an encounter with a limb. There was a huge 3/8ths gap to bridge and the handle material was much thinner than the frame.
This favor will yield a LOT of firewood this fall.
Automotive tire Bumper Fender Grass Automotive exterior
Bicycle tire Automotive tire Bicycle frame Hood Motor vehicle
Anyway not pretty but should hold.
I need to maby cut a stick or two I have a tree down in a fair spot near my gravel pit . I like to break up the branches for getting the big stuff to burn if you run out of small stuff it could put you in a difficult place for getting the big stuff going .
OK...a little explanation....what sticks?..power setting? (y)
It looks fine with the paint...and most important ...it is useable again...good work
Being I could work on the door in the garage, I used the MIG welder with .035 solid wire with C25 shielding gas. The handle itself was real thin so I had to use pretty low heat and had to build up a lot of metal to bridge the 3/8 ths gap after bending the handle back once there was sufficient material to handle the heat, turned up the heat a LOT and blended it all together. Difficulty was added with the door latch mechanism being in the way so I couldn't prep as well as I would have liked with a grinder.
We took the plexiglass window out so as to not pit it from welding. Put a piece of metal to shield the rubber gasketing.
  • Like
Reactions: mikeinri
Yeah, you forget about the hot sputter from the MIG torch. I was welding on my snow pusher & kneeling on a foam - rubber pad - well it looked like swiss cheese after! :LOL:
Sometimes jeans & shirt look like that too.
Wearing nylon tennis shoes isn't the greatest idea either. Those little spatters hurt. o_O
  • Haha
Reactions: mopar65pa
Parts collector
It ruins shoe laces unless they are leather too.
  • Like
Reactions: 77cruiser
Ever have it go down inside your shirt?:eek:
  • Like
