After a summer's worth of issues with the K532 rebuild on my HT, it's up and running and all is well. I was wondering if the four way blade could be hooked to it. Since it has a fel with it's own subframe that could be dicey. Interestingly enough, I can use the tiller with that subframe and loader attached. Well, whoever did that loader and subframe did a heck of a good job! I rolled the HT over the the snowblade for a quick look-see and found that it definately can be mounted with just minor modification. Since the loader frame is using the front pins between the brackets, I'll have to move the snow blade attach points a bit inboard. I figure about a 3/4" inch offset. They'll ride on the same pins as the subframe. The bucket will still reach within ten inches of the ground. Just raise the bucket enough and the snow blade can still go up/down and swivel. Neat. That's next week's project! YAY! Moving snow with that fel is a PAIN! The blade is so much faster...and better.
