I need a new edge for my blade.
Wonder how that plastic is going to hold up for you, do you have a link for that?
This completely replaces the steel edge?here is the link
http://www.ebay.com/itm/HEAVY-DUTY-UHMW-POLY-CUTTING-EDGE-54-JOHN-DEERE-SNOW-PLOW-SNOW-BLADE-pm-/320827373927?pt=LH_DefaultDomain_0&hash=item4ab2cd3967
Its pretty beefy, and I think it will be easier on the driveway. I searched through all of the feedback from the seller and saw nothing but positive comments on it, but time will tell
yeah, thats the way i have it installedThis completely replaces the steel edge?
Lets us know how it works for you, in the mean time I'm gonna fab a steel cheap one myself.yeah, thats the way i have it installed
here is the link
Grainger or McMaster-Carr can sell the UHMW products.well i used it again today and I gotta say it seems to work great. I guess the real test will be to see how long it holds up. I saw in another post somewhere that someone was able to find the material these are made of (uhmw poly) and was able to make like 3 for 30$ but Im not sure where the material was found. Id be interested to know if anyone else has used the same type, and how it held up. If the claims made on the ebay listing are true then I think this is the way to go.
I bought 2 pieces of 1" x 4.25" x 54" UHMW Poly from a guy on ebay for $50 shipped. I cut one in half so that I could make two 2" wide wear edges. I put one on. I have only had to plow the driveway once, but I have moved dirt with it numerous times. At 1" thick, it seems to be really tough and I think it will wear quite well. I will be able to get 4 wear edges out of the material I bought. The friction between the UHMW Poly and the paved driveway is very low even when I put down pressure on it to scrape packed snow.well i used it again today and I gotta say it seems to work great. I guess the real test will be to see how long it holds up. I saw in another post somewhere that someone was able to find the material these are made of (uhmw poly) and was able to make like 3 for 30$ but Im not sure where the material was found. Id be interested to know if anyone else has used the same type, and how it held up. If the claims made on the ebay listing are true then I think this is the way to go.
We had about 2 inches of snow last night that was slushy when it came down then froze overnight so I decide to use my 300 with the 54 inch blade instead of my X300 and the blower. The blade with that plastic edge worked like a champ and the 300 absolutely bulldozed through the frozen snow but one thing I have decided is absolutely necessary which I don't have is the power angle, sure wish I would have held out until I found me one at the right price....:banghead3Well I bit the bullet and ordered me one of these today, hope I didn't waste 53 bucks.
It did great in the grass, just kinda bent it over some but never dug into it at all, the plastic has a kind of round edge (for now) so I'm sure that's why. I'm curious to see how it holds up after several uses.How did the plastic do when you were pushing onto the yard? That is one thing I like about my Rubber edges, it doesn't tear up the grass. :trink40:
I got about 3-4" here just south of town. slkpkIt did great in the grass, just kinda bent it over some but never dug into it at all, the plastic has a kind of round edge (for now) so I'm sure that's why. I'm curious to see how it holds up after several uses.
