Well that, and some other goodies. The hitch is complete with the lift rod which still leaves my spare rod in reserve. It is missing the bushings at the pivot points, so I'll need to find/make some of those eventually. There's a 50" mower deck that should be usable. It's a bit beat up and has a hole near the top of the discharge chute but is complete and doesn't appear to have any serious rust. There is a nice crack-free front grill casting as well.
I have been ignoring riders until I find a 450. However, this one tempted me beyond the limits of my self-control. The seller had this tractor listed for sale for a few weeks for $150 with a poor title and description but at least a photo. Then he dropped his price and I figured I'd be stupid to pass it up even with the 5 hour round trip. It's a 1973 816 (SN 20140A) with most of the 816 goodies still attached (snow plow latches, hydraulic lift, rear PTO axle block, etc.). The Onan CCKA has had the shrouds and starter removed. I turned the motor over by hand a few times and it has compression in both sides. There are various things that have been kludged together here and there like the tie rods and an electric fuel pump, there is almost 1/3 turn of slop in the steering, and the left rear wheel hub is loose. The steering wheel itself is in really nice shape, though,. All tires are holding air and the cigarette lighter is still there.
My youthful optimism has me hoping that someone was operating the tractor and got something shoved into the flywheel and that's the reason those parts got removed. All of the fan blades in the flywheel are sheared off although the ring gear is still intact. I'll be keeping an eye out for a replacement flywheel and grass screen. Like so many other projects of mine, time is on my side for a while...
The plan for now is to get the engine back in usable shape. If I get it running and it doesn't need a rebuild, I'll see if the PTO is any good. Honestly, if the PTO is out, it's not a big deal because I'll still be able to use the rear hitch for garden implements (homemade and I may pick up a little Brinly moldboard plow just for fun). It could also get winter log pulling duty. I'm a bit bummed out that it's too late to have a limited-slip differential; maybe I'll splurge and get some steering brakes for it in the future. Seems like there was evidence that the LSDs were weaker, too. Anyhow, I'll probably take some of the nice factory parts from the 8102 to swap onto the 816 for the homemade things. Hopefully I'll end up with a nice, usable 816 and a decent working 8102 when everything is finished.
I haven't been this excited for quite some time :bananapow
