In 2005 I bought the 40 gallon Fimco trailer sprayer with the 2.1 gal. electric pump with a 7 nozzle boom. This has been a great little sprayer and with the 40 gal capacity it's just right for my 3 acres. Last year I upgraded the pump to the 3.8 gal per minute pump and switched to flood jet nozzles hoping top get more recirculation to keep the product in suspension. I use 28% nitrogen for fert and it's heavy and needs to be recirculated while spraying.
If anyone is looking to buy one I might suggest going with the gas version and roller pump if your looking to spray anything heavy so you can use the by pass to keep everything in suspension. The by pass on the electric pump leaves a little bit to be desired for recirculating and spraying at the same time.
Overall I'm would give it 9 out of 10 rating. For spraying regular herbicides and other liquid fert it does extremely well. slkpk
