Hello Larry and welcome to MTF!
Let's get you over to the Big Tractor Forum so you can get some help on your questions.
Here's the link to the Massey Fergusons where the Ferguson TE20 model falls into:
http://www.mytractorforum.com/forumdisplay.php?f=32
Post your questions at the above link for faster responses.
Here's a PDF owner's manual link to the Ferguson TO20 (Tractor Overseas) which is similar and has the same engine as the TE20 (Tractor England):
http://www.ntractorclub.com/manuals/tractors/Ferguson TO-20 - Operation and Maintenance.pdf
Valve adjustment is on page #15.
I've attached a Ferguson Maintenance sheet with several Ferguson models listed (No info. on vavle clearance?? TO20 Manual says to set both valves while cold at 0.014 in this firing order 1-3-4-2 each cylinder at TDC in that order). Also attached is a parts list for the Ferguson tractors.
I'll look through my files for a TE20 manual if I have one??
Good luck on your repair!
