Fender pan mount - help
1257 Views 6 Replies 4 Participants Last post by  JayClay
Hello fellas
Noticed my rear fender pan was a little loose this past weekend on my 332. Upon inspection I found that one of the rear rubber mounts is torn. Is this a part that I can still get :praying: or am I going to need to keep and eye on evilBAY?
Thanks!
1 - 7 of 7 Posts
Hello fellas
Thanks!
JayClay,
Do you have a picture of the rubber mount?
My 318 fender pan bolts right to the frame with 4 bolts and washers. No rubber mounts at all.
I can get a picture when I get home (at work) :hide: . It looks like a 1 1/2" round 3/4" thick rubber donut, with a bolt in the center. The rubber has torn just below the base of the bolt. There is no real way to fix it good and strong without replacing it. I might just have to make somthing up, but was hoping that this was somthing that I could get.
Hello fellas
Thanks!
Look at these: I think index #4 or pn M76270 is what you are after.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Probably needs the isolation for that big bad diesel.
Thats it! Thanks a bunch! :thanku:
Ya, you can still get them. I replaced all 4 on the seat pan of my 112 last fall
yeah, though that site found out that local dealer has them in stock for about $5 each. I got all 4, why not, there old anyway. Also got some other part while I was ordering.
1 - 7 of 7 Posts
